Can 3cx phone system and 3cx phone install on the same PC?
Discussion in '3CX Phone System - General' started by mayuqiang, Nov 7, 2007.
  1. mayuqiang
    Oct 25, 2007
    5
    Can 3cx phone system and 3cx phone be installed on a same PC?
    I install 3cx phone system (Version 3.1) and 3cx phone on a same PC. When I use another sip phone to call 3cx phone, 3cx phone ring but calling party is disconnected. 3cx phone system record show called party (3cx phone) is busy.
    Why? whether because 3cx phone system and 3cx phone can't be installed on a same PC?
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Hallo,
    I can tell you that I have similar sitaution. I have installed 3CX Phone system on My Laptop for testing purpises and on the same Laptom also X-Lite phone and it work just fine.
    I have han never any problems making and receiving calls on X-Lite.
    rgards,
  3. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    Yes it is possible not a issue at all....
  4. LORD ORION
    Jul 23, 2007
    39
    Change the sip signaling ports
    eg: 3cx is running on 5060? Change the softphone to 5061 etc...
