Can anyone suggest a high speed VPN?
Discussion in '3CX Phone System - General' started by Rochester, Dec 7, 2012.
  1. Rochester
    Dec 7, 2012
    Hi guys! I need your advice. I want to buy a VPN, but I need a really good one, with a high speed and easy to handle...something like one click and done :) Can you suggest anything? It would be great if I can first try it for free. Thanks in advance!
    11,127
    330
    You are asking a very vague (not a lot of specifics about your actual VPN need), in a very specific forum (3CX PBX). If you search the forum, VPN use with the PBX has come up in regards to bypassing country specific blockage/restrictions of VoIP services.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    It depends vastly on available internet connections and stability, from hardware point I would recommend using MikroTik routers, quite easy to set a VPN plus performing quite well (reaching speeds like 270 Mbit/s on a Gigabit connection for IPsec tunnel with high-end models, just $695 per piece). Depends what you consider good VPN.
    Regards
  4. Rochester
    Dec 7, 2012
    Thank you for your advice!! It seems to me that I will try MikroTik routers.To my mind, a good VPN,is a service which guarantees my privacy, is high speed, and why not is a free one :D :D . It seems funny, I think for you, but I have heard about Kepard that it is a free VPN, and it has also a high speed. Have you heard abot this VPN service? Please tell me if it worths to be tried. ;) ;)
