Can Calls Get Stuck?
Discussion in '3CX Phone System - General' started by SIPfun, Jun 27, 2008.
  1. SIPfun
    Jun 23, 2008
    56
    Ok... When I call from my cell to the PBX, I hear no audio (although I can press keys and they'll forward correctly on the DR)...
    I call from any other line (or cell), and I hear the DR correctly. I can't explain it.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Codecs?
  3. SIPfun
    Jun 23, 2008
    56
    Is there a preferred codec order?
    Can I mix and match between the VOIP provider and the extensions?
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    For VoIP provider - yes, you can set it in provider's settings.
    Phones have codecs order in their own settings. We can not force it in any way.
    Binding VoIP provider to media server may help you to solve the problem.
  5. darrellchapman
    Nov 26, 2007
    268
    Your provider should provide you with a preferred order or at least which codecs they are capable of using. Beyond that it's a matter of personal preference (others may argue this point, though).
    Mine are set in this order:
    G.729
    G.711 U-law
    G.711 A-Law
    GSM
    One of my providers does not support G.729 so I obviously don't use that codec with that provider.
    Yes, you can mix and match and define different codecs your phone will use however I believe that you need to set 3CX up so that "PBX delivers audio." This way 3CX can transcode the data in the other codec (if necessary).
  6. SIPfun
    Jun 23, 2008
    56
    G.729 isn't available in any of my ATAs... And it looks like my VOIP provider uses G.711 U-law, and all my ATAs are set to that.
    Strangely, the one-way audio from my cell went away.
