can dial inside and outside but no voice
Discussion in '3CX Phone System - General' started by nngeek, Dec 26, 2007.
  1. nngeek
    Sep 4, 2007
    9
    ext 102 is on the outside. I have the 3cx v3 server in a dmz, no ports blocked. I can here the softphone ringing but when I pick up there is no sound inside or outside. I am using 3cv voip client on the outside. Here is the error log
    17:43:42.006 MediaServerReporting::RTPReceiver [MS105000] Call(215) Ext.102: No RTP packets were received on 000001D1@:remoteAddr=x.x.x.x:1242,extAddr=0.0.0.0:0,localAddr=192.168.2.3:7428
    17:43:41.990 StratInOut::eek:nCancel [CM104009] Call(215): Call from Ext.102 to 999 has been terminated
    17:43:26.709 CallLegImpl::eek:nConnected [CM103001] Call(215): Created audio channel for Ext.102 (12.160.93.202:1242) with Media Server (192.168.2.3:7428)
    17:43:26.677 CallConf::eek:nIncoming [CM103002] Call(215): Incoming call from 102 (Ext.102) to sip:999@x.x.x.x:5060
    I can not figure out what is going on...
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    STUN
    Hi.
    Have you set the same STUN server in both 3CX and VoIP Client?
    Im not sure, but using v5 client on v3 server may be a problem.
    Have you tried any other softphone from external?
  3. jparisi
    Oct 1, 2007
    92
    You have to forward ports 10000-20000 for the voice traffic. It looks like your server may be in a DMZ but it's still NAT'd because the IP is a 192.168.x.x and that's a private range.
  4. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Have you selected the bind media server option?
