- Joined
- Jul 11, 2011
- Messages
- 7
- Reaction score
- 0
leejor said:Unless the calls come from known caller ID's, then there is no way to block them. Most are automated and require the called party to do something, (press a key) to accept the call. It is up to you to train your employees not to accept them.
If your number is being targeted as a part of a scam, then it should end if none of the calls are accepted. Otherwise, report it to your provider who can contact the company where the calls are originating. They may be able to do something.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
