can I connect 3CX Phone to a Cisco Unified CME System??
Discussion in '3CX Phone System - General' started by mishi, Mar 29, 2010.
  1. mishi
    Mar 29, 2010
    Regards
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Probably not because Cisco Unified CME is not a standards based system.
  3. comresource
    comresource Member
    May 22, 2009
    303
    Yes you can, but you have to add it as a SIP phone. Your much better off using Cisco's IP Communicator if you are connecting to a CME system.
