Can I disable "hold while I transfer" sound?
Discussion in '3CX Phone System - General' started by Murfy, Jun 30, 2015.
  1. Murfy
    Jun 30, 2015
    5
    I have created a digital receptionist to welcome callers. This transfers after 0 seconds to my queue. However it seems to be impossible to disable the woman sayining "please hold while I transfer your call" (I have set it to Dutch so I don't know the exact phrasing).
    Is there any way to disable that?
  2. Deepest
    Nov 9, 2012
    45
    Hi Murphy
    You can find the audio file and rename it. Then add a new blank audio file with the original file name.
    The audio file is named please_hold.wav.
    Cheers
    PS i have this running on most of my customers with call ques set up.
  3. Murfy
    Jun 30, 2015
    5
    OK, thanks, that worked.
  4. Deepest
    Nov 9, 2012
    45
    Cool glad i could help.
