Can I have direct remote extensions connect via hostname?
Discussion in '3CX Phone System - General' started by FGCUHank, Jul 27, 2012.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    We have 2 Internet connections, and a dual wan router. We are in a fairly rural area and both connections are lousy. Between the two, you could argue I have one reliable connection.
    The dual wan router is configured to move the rules back and forth and our external dns is configured to fail over as well.
    I have some direct remote extensions that have been working when the link they are configured for is up. They connect via IP address as described in the remote-extensions blog entry on the site.
    I tried configuring a remote extension to connect to a valid host name. telecom.notmydomainname.com and watched it try to register. The 3cx security blacklisted the client. The hostname resolves correctly from the 3cx server and the public net.
    Is what I am trying to do legal/possible in SIP?
    Thanks in advance.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Re: Can I have direct remote extensions connect via hostname
    Perhaps.
    I suggest you de-blacklist the ip and then try your test again, but this time look at the logs. It would seem that using your fqdn did resolve to your ip and then traversed the firewall to 3cx, so then the question is why 3cx blacklisted the ip? This is usually because the extension was not authorized for use outside the LAN or maybe for invalid credentials.
  3. leejor
    10,737
    278
    If you want a remote extension to connect using a URL (I assume you are using a dynamic DNS service), then that name (name. telecom.notmydomainname.com) has to be datafilled in 3CX as the Domain Name (advanced settings)
  4. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Thanks Leejor, you may have it.
    I have our domain parked at dnsmadeeasy.com We have 2 statics, one on each circuit. The cable is the main, if it goes down the router fails to the dsl and dnsmadeeasy points all the records to the ip of the dsl.
    I'll give it a shot and post back.
  5. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Thanks Leejor, this seems to have done the trick.
