Can i send a command from the computer to make a call
Discussion in '3CX Phone System - General' started by code937, Jul 27, 2007.
  1. code937
    Jul 27, 2007
    6
    Is it possible to send a command from the computer to make a call from my grandstream phone at ext 100 ? because im making some contact software and it would be nice to click the number and automatically call it.
    Thanks in advance guys :)
    PS: Your software is out of this world!! thank you so much :D :roll:
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    We can use 3CX CallAssistant.
  3. code937
    Jul 27, 2007
    6
    i know :) but id like to make my software able to dial a number too :D
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    OK. I think our site admin can be answer this question.
  5. code937
    Jul 27, 2007
    6
    would it help if i said im coding in vb6 ... also an idea is i could just call an address within a web browser, if there was a command that would call a specific number ?
    192.168.0.2:5020@01234
    thats just an example of course that wouldnt work :) but i think you catch my drift :)
  6. code937
    Jul 27, 2007
    6
    not really possible then ???
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You can create SIP client that will simply create two calls using direct SIP call to PBX and then make attendant transfer. result of this manipulation - both parties will be connected to one call.
    Regards,
    Stepan
  8. code937
    Jul 27, 2007
    6
    could you go into a little more detail in how this could be achieved?
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    RFC 3261, RFC 3264
    reSIProcate library also useful.
    P.S. You can use it to implement functionality right now. Otherwise, you need to wait until API will be provided.
