Can i setup Bridge using FQDN ???
Discussion in '3CX Phone System - General' started by seetarc, Jul 26, 2011.
  1. seetarc
    Aug 29, 2008
    45
    I have a client with 3 x 3CX phone system sites. two sites have static IP. However the third site has dynamic IP so we are using FQDN.dyndns.xxx to resolve IP address
    Now the challenge is the Bridge Tunnel across the sites. Does anyone know if using FQDN works setting up the Bridge. I am not successful with it for now. Using IP address works okay.
    10,870
    304
    It will work, I've got it up and running that way. First, check the 3CX server log to see if there is an indication of why (rejected?) the slave isn't registering, or, if there is any sign of a registration attempt. One of the common problems when using a dynamic IP and FQDN...is, that people forget to put the URL into the Domain Name setting in 3CX. So, if you have a DyNDNS service name of my3cxathome.dyndns.info , that is what your Domain Name will be. Without that, when a call or registration attempt is made using the URL, 3CX rejects it.
