Can I transfer a call to my mobile
Discussion in 'CRM / Helpdesk / App Integration' started by rickytmp, Oct 7, 2011.
  1. rickytmp
    Oct 6, 2011
    13
    I can transfer a call to my extension, but if I am out, can I transfer the call to my mobile through outbound trunk like dialing this
    9[get CO runk],66778899123[my mobile no].
    Thanks for any help
    Ricky
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Yes, from the VAD application just transfer to your extension, and configure it in 3CX to forward the call to your mobile when you're out of office.
  3. rickytmp
    Oct 6, 2011
    13
    Thanks VAD_Support
