Can I use 2 VOIP Connections (providers)?
Discussion in '3CX Phone System - General' started by SIPfun, Jun 23, 2008.
  1. SIPfun
    Jun 23, 2008
    56
    I have 2 VOIP accounts with the same provider... Are there any issues attempting to make connections to both?
  2. Philco
    Philco Member
    Nov 10, 2007
    364
    I dont think so,
    Phil
  3. SIPfun
    Jun 23, 2008
    56
    You don't think I can use 2 providers, or you don't think I should have issues? :)
  4. Philco
    Philco Member
    Nov 10, 2007
    364
    Sorry about that, silly me. I dont think there is any issues.. You are able to use two accounts from the same provider on 3cx.
    Regards
    Phil
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    yes, 2 accounts with the same provider works fine
    regards
  6. alek
    Aug 2, 2008
    I have two providers , works fine to dial out. But when someone calls in on of the external numbers, 3cx cant distinguish what number the caller is calling in on. thus it calls on all ring groups.
    Does anyone have an idea how to fix this?
  7. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Alek, if these are two separate accounts (two numbers ?) it should be down to your inbound rules for the accounts as to how the incoming calls are routed.
    Phil
