Can I use any hardphone with 3CX?
Discussion in '3CX Phone System - General' started by MarkAmations, Dec 29, 2014.
  1. MarkAmations
    Dec 29, 2014
    I was just wondering can I use any IP Phone with 3CX because I can get a couple of cheap handsets and would prefer to not exceed £25 per phone.
    Any suggestions or should I get a pair of second handers
    Many Thanks
    - Mark
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,129
    207
    Lots of ip Phones "Work"... but only a handful of manufacturers are supported by 3cx for full compatibility.
    You might find some used Yealinks for under $40 US on Ebay.
  3. MarkAmations
    Dec 29, 2014
    If I only want to send and receive internal calls, what would be the best option there?
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    The key is to find a SIP 2.0 compatible IP-Phone. There are many IP-Phones that use a proprietary signaling scheme so that the phones are "tied" to the IP-PBX manufacturer. While some of these may have firmware that can be loaded which then makes the device SIP compatible, there may still be some obstacles to overcome in order to get the full functionality.
    Yealink is supported and has a T-19 model that might be somewhere close to your price range. The retail price is around $50 USD, but you might be able to get somewhat cheaper by looking around. Whatever you do, you will be best served by looking for a phone that is on the 3CX supported list as while others can be made to work, selecting a supported phone eases the potential headaches.
  5. MarkAmations
    Dec 29, 2014
    Ok, thanks for the help guys :D
