Can iLBC be disabled in V5
Discussion in '3CX Phone System - General' started by MajoR_Mess, Mar 28, 2008.
  1. MajoR_Mess
    Dec 4, 2007
    11
  2. jacky18
    Feb 16, 2008
    16
    Major_Mess
    I think I have the same problem as yourself. Inbound calls no longer works. I wonder removing the iblc dll from the installation helps at all.
    I need to try it out myself as I have V5 in a VM and having major headache with MNF as incoming doesn't work.
  3. jacky18
    Feb 16, 2008
    16
    Hey mate,
    I've tried V5 and now testing V6, same problem. MyNetFone just doesn't work unless you apply the workaround of removing the ilbc.dll file manually from the installation bin directory.
    Though GUI wise, it looks like it's disabled, but seems it is still doing it since V3
