Can not add change provision template / Mac address provision
Discussion in '3CX Phone System - General' started by Brian Suing, Dec 19, 2016.
  1. Brian Suing
    Dec 16, 2016
    6
    Thanks for reading my post. This is for a new installation v15. It was all working as it should and I do have many phones provisioned with a custom template. These phones do show up as "Yealink (Custom Template)" and the MAC address does show.
    I did attempt to create a Google Push I modified the two fields API key and Project number. I abandoned this (begin of server error 500) and removed the data in the fields. The push account is now "3cx account" as it was before.
    I was getting server error when I tried to edit the extension. :( I re-installed server and restored from full backup. (I do not see internal server error 500 anymore)
    Now, a problem exists where I can not add phones with my custom template. New phones show up as they should but I can not add them to extensions using the custom template. I can not change the templates used on provisioned phones. I can get a phone to work using STOCK templates and the MAC will be correct. I can not reprovision the new phones from the management console with a change to the custom template..
    Another Clue is that there is never a list of codecs. "+ add codecs" button does nothing to existing working extensions.
    I told a working extension to "->Reprovision" and it did work using the custom template that I specified last month.
    If I take an extension and "Add Phone" i can choose the custom template and enter the MAC address, but it does nothing when I click "OK"
    This has been a problem that I can not figure out. Been reading the forums to no avail. Plz help. and Thanks in advance.
    #1 Brian Suing, Dec 19, 2016
  2. Brian Suing
    Dec 16, 2016
    6
    I did fix this myself. I was able to finally create a valid CSV file. Looks like this is how I will add extensions.
    This thread can be deleted.
