Can not call to other number
Discussion in '3CX Phone System - General' started by vaohama, Mar 2, 2007.
  1. vaohama
    Feb 21, 2007
    6
    Dear: All
    I'm Danai from Thailand Thank you for your good program easy to install
    I'm have problem not sure How can i solve it i can not call to other in the same SIP- server
    Windows Server 2003
    Symantec Antivirus
    i can call to server
    but can not call from PC 2 PC
    i use X-Ten for IP phone
    Please advice
    Thank you
    Danai
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Do the machines have firewalls enabled? or a firewall in the network?
  3. vaohama
    Feb 21, 2007
    6
    Thank you for your advice
    I think so
    I try to re-install for new and remove all sec software and try to test again tomorrow
    Thank you,
    Danai,
    Friend from Thailand
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,913
    220
    It so happens i am in thailand as i reply to your message. Lovely place! :)
    In regards to your issue the best is to work as follows
    1. Check if any firewalls are active on the PCs or the Server, switch off if yes to ascertain its not a firewall problem.
    2. Check that the extensions have been registered correctly with 3CX Phone System.
    3. Dial the other extension and check the server status log - it will show the connection logs and what exact ips are being dialed. Check that these are indeed correct.
    4. Check the server status logs - is the server getting a response from the the extension? See this FAQ how to analyze the server status logs in more detail:
    http://www.3cx.com/support/troubleshoot_sip_call.html
    Let us know how it goes!
