can not connect to virtual receptionist
Discussion in '3CX Phone System - General' started by ambiq11, Oct 6, 2010.
  1. ambiq11
    Oct 6, 2010
    I have create a virtual receptionist, add menu file(recorded with required format) and when i make a call, call drops after 2 sec..
    when i forward to extension- works fine, when to IVR, dropped call..
    Please help!!!!!!
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Check your system extension status first
    We are still getting a (known) problem (today) with system extensions unregistering themselves. A restart of the pbx services helps.
