Can not Dial on menu tree
Discussion in '3CX Phone System - General' started by tjericson, Jan 31, 2009.
  1. tjericson
    Jan 29, 2009
    25
    I have 3cx version 7.0.4744.0.
    I have a problem with some calls. When I get a menu tree (press 1 for X, etc.). It does not recognize any of the dialed numbers. Any ideas?
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    What device are you using to access the Menu with?
  3. tjericson
    Jan 29, 2009
    25
    Cisco 7940
    Cisco 7960
    SPA 921
    SPA 941
    it is random. Will work sometimes on certain devices and sometimes it doesn't. And it NEVER works when the device is outside the firewall.
  4. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Are you refering to menu trees from 3cx? Like, for example, your voicemail menu? Or remote systems that you have called and need to interact with a menu system?
    What dtmf setting are you using on the phones?
    Mike
  5. tjericson
    Jan 29, 2009
    25
    I am talking about external menu trees when you call comcast or other similar large companies.
    I am not sure about the dtmf setting, what should I be using and where can i find the setting on my phones?
    Thanks!!
  6. worksighted
    Aug 19, 2008
    204
    Are you using a VoIP provider? If so, then you need to set the setting to whatever they want it to be. RFC 2833 is the most typical. But Inband and SIP Info are the other two options.
  7. tjericson
    Jan 29, 2009
    25
    Inphonex is the VOIP Provider.
  8. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    As far as you didn't provide any information requsted in http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html ...
    then:
    I'm not sure that it is possible... but...
    Could you please ask VoIP provider about it?
    Our PBX is just a source of signals. The delivery is the duty of the provider.
    If some of signals may confuse equipment of provider then we are ready to fix it (and/or provide workaround)
