Can not get Cisco 7940 to Register
Discussion in '3CX Phone System - General' started by Anonymous, Sep 3, 2006.
  1. Anonymous
    Anonymous Guest
    I am having trouble getting my Cisco 7940 to register with the PBX. Here is the SIPDefault.cnf syntax I am using...
    # SIP Default Generic Configuration File
    # Image Version
    image_version: P0S3-08-2-00
    # Proxy Server
    proxy1_address: 192.168.1.254 ; Can be dotted IP or FQDN
    # Proxy Server Port (default - 5060)
    proxy1_port: 5060
    # Proxy Registration (0-disable (default), 1-enable)
    proxy_register: 1
    # Phone Registration Expiration [1-3932100 sec] (Default - 3600)
    timer_register_expires: 3600
    # Codec for media stream (g711ulaw (default), g711alaw, g729a)
    preferred_codec: g711alaw
    Here is the Syntax from the SIP000AB78D736A.cnf file:
    # SIP Configuration Generic File
    # Line 1 appearance
    line1_name: Mike Bellini
    # Line 1 Registration Authentication
    line1_authname: 100
    # Line 1 Registration Password
    line1_password: password
    The registration authentication name is the same as the Authentication ID in 3CX as is the password.
    Any ideas?
  2. Anonymous
    Anonymous Guest
    I figured it out.
    For future reference, the Line1_name: value in the SIP<MACAddress>.cnf file needs to match the Authentication ID in 3CX.
    Simple. Great product. I just purchased a VoIP gateway from Grandstream so I will be playing with it a ton more next week. Thanks!
    Mike
  3. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Thanks for the feedback. By the mentioned;
    I assume you have solved your issue. Thanks for the tip, I hope all is plain sailing with the Grandstream. If anything just post here on the forums and I would gladly help anyway possible.
  4. Anonymous
    Anonymous Guest
    Cisco 7970 Phone
    Has anyone got a Cisco 7970 or 7960 with the Universal Application Loader configuration working with 3CX?
