Can not get Inbound call to work
ryanhandoko
Hi all. Greeting from Thailand.
I have a problem with 3cx Phone System.
Here is the log:
Registration all LAN extension and VOIP Provider (all success)
14-Jun-2013 03:42:05.175 [CM504001]: Endpoint Extn:109: new contact is registered. Contact(s): [sip:[email protected]:60097 / 109]
14-Jun-2013 03:40:58.639 [CM504001]: Endpoint Extn:100: new contact is registered. Contact(s): [sip:[email protected]:58501 / 100]
14-Jun-2013 03:40:28.437 [CM504001]: Endpoint Extn:108: new contact is registered. Contact(s): [sip:[email protected]:42986 / 108]
14-Jun-2013 03:40:14.366 [CM504001]: Endpoint Ivr:EndCall: new contact is registered. Contact(s): [sip:[email protected]:40600 / EndCall]
14-Jun-2013 03:40:14.366 [CM504001]: Endpoint Ivr:HOL: new contact is registered. Contact(s): [sip:[email protected]:40600 / HOL]
14-Jun-2013 03:40:14.363 [CM504001]: Endpoint VMail:999: new contact is registered. Contact(s): [sip:[email protected]:40600 / 999]
14-Jun-2013 03:40:12.993 [CM504001]: Endpoint ParkOrb:*1: new contact is registered. Contact(s): [sip:*[email protected]:40000 / *1]
14-Jun-2013 03:40:12.992 [CM504001]: Endpoint ParkOrb:*0: new contact is registered. Contact(s): [sip:*[email protected]:40000 / *0]
14-Jun-2013 03:40:12.966 [CM504001]: Endpoint ParkOrb:*777: new contact is registered. Contact(s): [sip:*[email protected]:40000 / *777]
14-Jun-2013 03:39:56.396 [CM504004]: Registration succeeded for: Lc:10001(@Skype[<sip:9905*****@sip.skype.com:5060>])
14-Jun-2013 03:39:55.863 [CM504004]: Registration succeeded for: Lc:10002(@Voffice[<sip:**60***@jakarta.voffice.co.id:5060>])
14-Jun-2013 03:39:55.411 [CM504003]: Sent registration request for Lc:10001(@Skype[<sip:9905******@sip.skype.com:5060>])
14-Jun-2013 03:39:55.367 [CM504003]: Sent registration request for Lc:10002(@Voffice[<sip:**60***@jakarta.voffice.co.id:5060>])
14-Jun-2013 03:39:55.265 IP(s) added:[10.4.1.252]
14-Jun-2013 03:39:53.267 [CM504008]: Fax Service: Fax.888 registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
14-Jun-2013 03:39:52.986 [EC200002]: Media server is connected:
application:phone-PC:0/MediaServer
local:127.0.0.1:5482
remote:127.0.0.1:49175
14-Jun-2013 03:39:48.957 [CM504004]: Registration succeeded for: Lc:10001(@Skype[<sip:9905******@sip.skype.com:5060>])
14-Jun-2013 03:39:48.519 [CM504004]: Registration succeeded for: Lc:10002(@Voffice[<sip:**60****@jakarta.voffice.co.id:5060>])
14-Jun-2013 03:39:47.883 [CM504003]: Sent registration request for Lc:10001(@Skype[<sip:99051*******@sip.skype.com:5060>])
14-Jun-2013 03:39:47.689 [CM504003]: Sent registration request for Lc:10002(@Voffice[<sip:**60***@jakarta.voffice.co.id:5060>])
14-Jun-2013 03:39:47.450 [CM506002]: Resolved SIP external IP:port (103.**.***.**:5060) on Transport 10.4.1.252:5060
14-Jun-2013 03:39:47.134 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.50.247.220:3478 over Transport 10.4.1.252:5060
14-Jun-2013 03:39:45.417 [CM501006]: Default Local IP address: [10.4.1.252]
14-Jun-2013 03:39:45.416 [CM501002]: Version: 11.0.28862.0
14-Jun-2013 03:39:45.416 [CM501001]: Start 3CX PhoneSystem Call Manager
Try to call out from 10001 Skype To 10002 DID provider
14-Jun-2013 03:51:36.965 Leg L:3.2[Line:10001>>6221**60****] is terminated: Cause: BYE from PBX
14-Jun-2013 03:51:36.965 [CM503008]: Call(C:3): Call is terminated
14-Jun-2013 03:51:36.965 Leg L:3.1[Extn] is terminated: Cause: BYE from 10.4.1.252:42986
14-Jun-2013 03:51:23.161 [CM503007]: Call(C:3): Line:10001>>6221***60**** has joined, contact <sip:9905******@sip.skype.com:5060>
14-Jun-2013 03:51:23.161 [CM503007]: Call(C:3): Extn:108 has joined, contact <sip:[email protected]:42986>
14-Jun-2013 03:51:23.161 L:3.2[Line:10001>>6221**60****] has joined to L:3.1[Extn]
14-Jun-2013 03:51:21.389 Currently active calls - 1: [3]
14-Jun-2013 03:51:07.165 [CM505003]: Provider:[Skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9905****@103.11.216.35:5060]
14-Jun-2013 03:51:02.192 [CM503025]: Call(C:3): Calling T:Line:10001>>6221**60****@[Dev:sip:9905*****@sip.skype.com:5060] for L:3.1[Extn]
14-Jun-2013 03:51:01.863 [CM503027]: Call(C:3): From: Extn:108 ("Remote VOIP" <sip:[email protected]:5060>) to T:Line:10001>>6221**60****@[Dev:sip:9905****@sip.skype.com:5060]
14-Jun-2013 03:51:01.863 [CM503004]: Call(C:3): Route 1: from L:3.1[Extn] to T:Line:10001>>6221**60****@[Dev:sip:9905******@sip.skype.com:5060]
14-Jun-2013 03:51:01.863 Line limit check: Current # of calls for line Lc:10001(@Skype[<sip:9905*****@sip.skype.com:5060>]) is 0; limit is 1
14-Jun-2013 03:51:01.863 Call(C:3): Call from Extn:108 to 96221**60**** matches outbound rule 'Rule for Skype'
14-Jun-2013 03:51:01.862 [CM503001]: Call(C:3): Incoming call from Extn:108 to <sip:96221**60****@10.4.1.252:5060>
For all incoming inbound call should go to extension 100 first.
My extension 100 do not ring. Please help what I miss in here.
Thank you
Any one know what I am missing in here?
Thank you
Sorry, but the logs do not seem to reflect what it is that you are having an issue with -
The first set of logs merely show the 3CX coming up and that all the services and providers are registered.
The second log set shows a call from extension 108 being made and routed out to Skype (1001). The two make a connection, but after having done so and waiting for a number of seconds, the extension sends a BYE and the call is terminated. I assume that "6221***60**** " is the number that is associated to the Jakarta SIp provider, but 3CX does not show any activity in the log relative to it. Either you hung up too soon, a firewall issue is preventing the Jakarta line from coming in, or the SIp provider is not routing correctly back to you.
Do you have a fixed IP? If so, you might be better off disabling STUN and installing the fixed public IP in the 3CX settings as well as at your providers.
You may also need to do a wireshark capture as it may have more detail.
Do you have your sip service pointed to a publicly accessible IP/domain?
Are you then port forwarding the required ports to the internal server?
Sorry if this is an obvious question/comment.
I make a call from my skype (1001) to my did number provide by jakarta.voffice.co.id (1002) The call out is working from skype. 1001 work fine
So in the log i should get incoming call from 1002 and go to extension 100 in my LAN. But there is nothing. So this mean that 3cx do not get any incoming call from jakarta.voffice.co.id. (the registration success)
I don't use any firewall program. internet->linksys wrt54gl (10.4.1.251)->3cx box OS windows 64bit(10.4.1.252)
I am using Internet Public Static IP.
I also have contact my voip provider they asking me to open this port:
SIP 5000-6000 TCP/UDP
RTP 10000-20000 UDP
I have open this port in my linksys wrt54gl and also change 3cx-network from detault 9000-9049 to the one that jakarta sip request. But still can not make this work.
I do use port forwarding at my linksys,
The port forwarding now is
5000-6000 both to 10.4.1.252 (3cx box IP)
10000-20000 both to 10.4.1.252
This the one that sip jakarta request me to change in the router. But still can not get any incoming call or any log in 3cx for incoming traffic from sip jakarta.
Note: use 3cx firewall checker stun server stun.3cx.com. Every single port show green status or success.
I put a test using xlite. set Jakarta SIP configuration at xlite. the incoming call work with xlite.
So there is some thing that I miss in here
Do you have the port pointing to go to a extension or a ring group when the all comes in? Also you may want to go to the management console VoIP provider--->Sourcd ID--->check the box source identification by DID--->Add DID--->Select All Box. attempt these changes and post what are the results of the test inbound calls to that trunk. Also what happens when you try to dial out on the vooffice trunk. Have you attempted an inbound calll to the skype trunk what are the results.
Ports forwareded should be,, thoug since you forwarded 5000-6000 you should have an problems with the ccall getting out.
5060 to ip pbx
9000-9049 to ip pbx
5000 to ip pbx
5090 ip pbx
I hope this helps.
Getting Started - Admin
Amar2
Get 3CX - Absolutely Free!
3CX
