Solved Can not hear when out of office
Discussion in '3CX Phone System - General' started by washaq, Jul 12, 2017.
Tags:
  1. washaq
    Jul 12, 2017
    i am new to cloud PBX system, i have installed 3cx to hyper-v server, and did port forwardings as below;
    https://pasteboard.co/GAzmzoW.jpg
    [​IMG]
    my problem is i can call any extentions and talk with them in office enviroment over wifi, but when i am out office i can call or some one in office can call me, but we cant talk, audio doesnt pass, the guy in the can hear me because he is connected to wifi but i can not hear him because i am out of office
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,416
    282
    Hello @washaq
    Please note that the RTP ports should be open for UDP and not TCP. Also 5060 and 5090 should be open for TCP and UDP. Make sure that the firewall checker located on the dashboard of the 3CX management console passes all tests and try the call again.
    Have a look at the following link that contains all the necessary info
    https://www.3cx.com/3cxacademy/videos/basic/nat-port-forwarding/
  3. business54
    Apr 20, 2016
    55
    Under extensions > Options do you have PBX Delivers Audio checked?
  4. washaq
    Jul 12, 2017
    Thank you very much problem solved
  5. washaq
    Jul 12, 2017
    it is not checked, but problem solved by forwarding correct ports.
    business54 likes this.
