Solved Can not make outbound calls
Discussion in '3CX Phone System - General' started by Michael1600, Jun 24, 2017.
  1. Michael1600
    Jun 23, 2017
    26
    Used PBX Express to host test system with 3CX (they use OVH servers) After 29 days the trail shut down. I was able to provision a basic system with one DID and make call via IOS and OX soft phone. Now have loaded 3CX onto my own OVH VPS server. I am using my previous key.
    Problem-can not seem to make outbound calls to my cell or home phone. The system can send recorded messages to the soft phones. I have set up inbound and outbound rules using documentation from my SIP provider-Flowroute. System seemed to work fine before.
    Could the problem be related to not releasing the FQDN prior to reinstalling the system on different server.
    Also I can not connect to my FQDN site with my browser.
  2. Bret Gordon
    Jun 16, 2017
    24
    oh, hey! :) pretty sure licensing is tied to original IP address, so you'll probably want to contact 3CX support on this one
  3. Michael1600
    Jun 23, 2017
    26
    Found the problem. Did not set up Outbound route properly. Had to set strip digits field to "0" and prepend field to "1"
    Bret Gordon likes this.
  4. Bret Gordon
    Jun 16, 2017
    24
    cool! love to see "solved" threads :)
