can not receive and send FAX
Discussion in '3CX Phone System - General' started by daniel.lindenthal, Aug 27, 2012.
  1. daniel.lindenthal
    Aug 27, 2012
    hi,
    I've installed 3CX v.11 with some extensionals. telefon is ok.
    but when i call the fax extension (from intern so as from extern) the connection will be closed in a second
    log:
    27-08-2012 17:20:42.975 Leg L:61.2[Fax] is terminated: Cause: 200 BYE from PBX
    27-08-2012 17:20:42.975 [CM503008]: Call(C:61): Call is terminated
    27-08-2012 17:20:42.972 Leg L:61.1[Extn] is terminated: Cause: 200 BYE from PBX
    27-08-2012 17:20:41.361 [CM503007]: Call(C:61): Fax:88 has joined, contact <sip:88@127.0.0.1:5100>
    27-08-2012 17:20:41.356 [CM503007]: Call(C:61): Extn:20 has joined, contact <sip:20@192.168.8.152:2048>
    27-08-2012 17:20:41.281 [CM503025]: Call(C:61): Calling T:Fax:88@[Dev:sip:88@127.0.0.1:5100;user=phone]
    27-08-2012 17:20:41.236 [CM503027]: Call(C:61): From: Extn:20 ("3 CX 2" <sip:20@192.168.8.173:5060>) to T:Fax:88@[Dev:sip:88@127.0.0.1:5100;user=phone]
    27-08-2012 17:20:41.236 [CM503004]: Call(C:61): Route 1: T:Fax:88@[Dev:sip:88@127.0.0.1:5100;user=phone]
    27-08-2012 17:20:41.232 [CM503001]: Call(C:61): Incoming call from Extn:20 to <sip:88@192.168.8.173:5060>
    how can I solve this Problem ?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,117
    206
    Are you on v11?
    Is Ext 20 a fax machine?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Extension 20 does not support t38.
  4. daniel.lindenthal
    Aug 27, 2012
    no ext. 20 is a telephone.
    we tried to call the Fax-server on 88 but we didn't get a fax signal
  5. daniel.lindenthal
    Aug 27, 2012
    @ sy:
    will the fax-server only answere if the incoming fax is t.38 ?
