Here is the server activity log from fresh startup of 3CX:
I have separated it into some useful chunks: Please go to bottom and read upwards:
There was no voicemail to be retrieved so I hung up VVVVV
13:52:17.407 [CM503008]: Call(2): Call is terminated
13:52:07.111 Currently active calls - 1: [2]
13:51:58.759 [CM503007]: Call(2): Device joined: sip:
[email protected]:40600;rinstance=b78b25979222f999
13:51:58.756 [CM503007]: Call(2): Device joined: sip:
[email protected]:5060;transport=udp;user=phone
13:51:58.745 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:
[email protected]:5060]
13:51:58.744 [CM503002]: Call(2): Alerting sip:
13:51:58.599 [CM503025]: Call(2): Calling Ext:Ext.999@[Dev:sip:
[email protected]:40600;rinstance=b78b25979222f999]
13:51:58.554 [CM503004]: Call(2): Route 1: Ext:Ext.999@[Dev:sip:
13:51:58.553 [CM503010]: Making route(s) to <sip:
[email protected]:5060;user=phone>
13:51:58.550 [CM505001]: Ext.105: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.5.3] PBX contact: [sip:
13:51:58.547 [CM503001]: Call(2): Incoming call from Ext.105 to <sip:
Go to phone running extension 105 and attempt play the voicemail ^^^^^^
13:49:26.576 [CM503008]: Call(1): Call is terminated
13:48:59.100 Currently active calls - 1: [1]
13:48:48.761 [CM503007]: Call(1): Device joined: sip:
13:48:48.759 [CM503007]: Call(1): Device joined: sip:
[email protected]:56813;rinstance=334bf805ad8c0516
13:48:48.749 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:
13:48:48.749 [CM503002]: Call(1): Alerting sip:
13:48:48.644 [CM503003]: Call(1): Call to sip:
[email protected]:5060 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.116:5060
13:48:48.622 [CM503025]: Call(1): Calling Ext:Ext.999@[Dev:sip:
13:48:48.563 [CM503005]: Call(1): Forwarding: Ext:Ext.999@[Dev:sip:
Call not answered within 10 seconds ^^^^^
13:48:38.585 [CM505001]: Ext.105: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.5.3] PBX contact: [sip:
13:48:38.585 [CM503002]: Call(1): Alerting sip:
13:48:38.505 [CM503025]: Call(1): Calling Ext:Ext.105@[Dev:sip:
[email protected]:5060;transport=udp;user=phone]
13:48:38.488 [CM503004]: Call(1): Route 1: Ext:Ext.105@[Dev:sip:
13:48:38.481 [CM503010]: Making route(s) to <sip:
[email protected]:5060>
13:48:38.478 [CM505001]: Ext.125: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:
13:48:38.475 [CM503001]: Call(1): Incoming call from Ext.125 to <sip:
TEST CALL ^^^^^
13:47:49.787 [CM504001]: Ext.125: new contact is registered. Contact(s): [sip:
[email protected]:56813;rinstance=334bf805ad8c0516/125]
13:47:31.412 [CM504004]: Registration succeeded for:
[email protected]
13:47:31.140 [CM504003]: Sent registration request for
[email protected]
13:47:31.039 IP(s) added:[192.168.1.119]
13:47:28.753 [CM504001]: Ext.SP9: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=21ef6f00a6e66d9d/SP9]
13:47:28.752 [CM504001]: Ext.SP8: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=835191378ab797de/SP8]
13:47:28.745 [CM504001]: Ext.SP7: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=5281f12adbaadbdf/SP7]
13:47:28.744 [CM504001]: Ext.SP6: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=235323e2fb84af6c/SP6]
13:47:28.736 [CM504001]: Ext.SP5: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=758bf874f1413ea8/SP5]
13:47:28.652 [CM504001]: Ext.SP4: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=2d6c43618eeb280e/SP4]
13:47:28.652 [CM504001]: Ext.SP3: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=b76f10944ada931d/SP3]
13:47:28.651 [CM504001]: Ext.SP2: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=7ea404249c585f0b/SP2]
13:47:28.651 [CM504001]: Ext.SP1: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=2eb4dd5c81895414/SP1]
13:47:28.650 [CM504001]: Ext.SP0: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=3bdbb03661820253/SP0]
13:47:28.646 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=366bf330ee8f5baa/*1]
13:47:28.635 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=4fa6eb717e60875f/*0]
13:47:28.628 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=168b4c6b45bc7a0f/*777]
13:47:28.618 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=00badd89d28ca86a/704]
13:47:28.618 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=2ad4f0639eed3040/703]
13:47:28.609 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=05233e734c9b57e1/702]
13:47:28.529 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=dfa095d5ab36b034/701]
13:47:28.529 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=13d1002dbc016230/700]
13:47:26.631 [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:
[email protected]:5060;transport=udp;user=phone/105]
13:47:25.332 [CM504001]: Ext.RecordFile: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=23c67e0b5c8c6e07/RecordFile]
13:47:25.331 [CM504001]: Ext.PlayFile: new contact is registered. Contact(s): [sip
[email protected]:40600;rinstance=a8bb80b44af22cbf/PlayFile]
13:47:25.323 [CM504001]: Ext.MakeCall: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=ab1d6a6284bfb5e4/MakeCall]
13:47:25.225 [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=c6de6eef67100a6d/IVRForward]
13:47:25.225 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=87ce5a30ec3a34ca/EndCall]
13:47:25.218 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=b78b25979222f999/999]
13:47:24.241 [CM504001]: Ext.DialCode: new contact is registered. Contact(s): [sip
[email protected]:5488/DialCode]
13:47:23.992 [EC100007]: External application is connected: application:Win-PBX:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:49172
13:47:23.488 [CM504008]: Fax Service: registered as sip:
[email protected]:5060 with contact sip:
[email protected]:5100;user=phone
13:47:22.967 [EC200002]: Media server is connected: application:Win-PBX:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:49170
13:47:22.872 [EC200005]: Parking Orbit server is connected: application:Win-PBX:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:49169
13:47:22.826 [EC200004]: IVR server is connected: application:Win-PBX:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:49166
13:47:22.810 [CM504004]: Registration succeeded for:
[email protected]
13:47:22.467 [CM504003]: Sent registration request for
[email protected]
13:47:22.295 [CM506001]: STUN request to resolve SIP external IP
ort mapping is sent to STUN server [ V4 96.9.132.83:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.1.119:5060 UDP target domain=unspecified mFlowKey=0 ]
13:47:21.094 [CM501006]: Default Local IP address: [192.168.1.119]
13:47:21.094 [CM501001]: Start 3CX PhoneSystem Call Manager
13:47:21.000 [EC200001]: Configuration server is connected: application:Win-PBX:5485/DBProvider local:127.0.0.1:49162 remote:127.0.0.1:5485
13:47:20.985 [CM501007]: *** Started Calls Controller thread ***
STARTUP ^^^^^
