Can not resolve target for call?
Discussion in '3CX Phone System - General' started by chrisjr, Apr 12, 2007.
  1. chrisjr
    Jan 23, 2007
    21
    I'm using broadvoice as my voip provider and I'm able to make outbound calls but I'm not able to call into the system. Has anybody encounter this?
    12:16:12.156 CallConf::eek:nIncoming Can not resolve target for call from "Oconomowoc WI"<sip:2624340477@147.135.20.128;user=phone>;tag=dfgi to "Chris Reoch"<sip:2627371045@192.168.2.9>
    12:16:12.156 CallConf::Rejected Call (C:5) is rejected: Target is not resolved
    12:16:12.140 CallConf::eek:nIncoming Incoming call from Ln:10001@BroadVoice2 to sip:2627371045@192.168.2.9
    11:57:56.656 CallConf::eek:nIncoming Can not resolve target for call from "Oconomowoc WI"<sip:2624340477@147.135.20.128;user=phone>;tag=jlnp to "Chris Reoch"<sip:2627371045@192.168.2.9>
    11:57:56.656 CallConf::Rejected Call (C:4) is rejected: Target is not resolved
    11:57:56.656 CallConf::eek:nIncoming Incoming call from Ln:10001@BroadVoice2 to sip:2627371045@192.168.2.9
  2. NigelG
    Mar 29, 2007
    48
    RE Calls
    Are you using a softphone or voip hardphone, it sounds like a firewall issue as the local IP is not resolving to the device called. If you are running a softphone then check the firewall settings on that PC.
    Regards
    NigelG
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Please, check your inbound rule for that line. Most probably you're trying to forward the call to non-registered extension which doesn't have a destination for non-registered case.
  4. chrisjr
    Jan 23, 2007
    21
    Inbound calls now working but getting disconnected early.
    Thanks, you where right. The inbound calls where going to an extension that does not exist. I was able to make an inbound call. When I do this the inbound call is always disconnected after 10-20 seconds. I don't know how to really read the log files that well. But it seems like Broadvoice is sending this hangup request??
    15:40:23.109 StratLink::eek:nHangUp Call(C:4): got Hang-Up from Ln:10001@BroadVoice2; reason: BYE
    15:40:16.578 CallLegImpl::eek:nConnected Established media channel for Ext.101: remote=192.168.2.10:5004; local=192.168.2.9:7014
    15:40:16.578 StratInOut::eek:nConnected Call from Ln:10001@BroadVoice2 to Ext.101 is established
    15:40:10.203 ??: from 'PhoneServer:0/MediaServer':DTMF detection off on EP:0000000A@
    15:40:06.250 CallLegImpl::eek:nConnected Established media channel for Ln:10001@BroadVoice2: remote=147.135.20.248:29204; local=67.53.129.195:9002
    15:40:06.203 CallConf::eek:nIncoming Incoming call from Ln:10001@BroadVoice2 to sip:2627371045@192.168.2.9
    15:39:51.531 StratLink::eek:nHangUp Call(C:3): got Hang-Up from Ln:10001@BroadVoice2; reason: BYE
    15:39:45.828 CallLegImpl::eek:nConnected Established media channel for Ext.101: remote=192.168.2.10:5004; local=192.168.2.9:7010
    15:39:45.828 StratInOut::eek:nConnected Call from Ln:10001@BroadVoice2 to Ext.101 is established
    15:39:39.937 ??: from 'PhoneServer:0/MediaServer':DTMF detection off on EP:00000007@
    15:39:34.781 CallLegImpl::eek:nConnected Established media channel for Ln:10001@BroadVoice2: remote=147.135.20.250:29144; local=67.53.129.195:9000
  5. archie
    3CX Support
    Aug 18, 2006
    1,299
    Check if VoIP provider is bound to Media Server in Advanced options for 3CX configuration. It should be bound to work correctly.
  6. chrisjr
    Jan 23, 2007
    21
    Outgoing Calls Disconnects
    I do have it binding to the media server. I've also tried the set the device as external. But still no luck? Could it be the phone? I'm using a Grandstream budge tone 200.
