Can not set Global Time Zone
Discussion in '3CX Phone System - General' started by sunkiddance, Jul 20, 2016.
  1. sunkiddance
    Jul 12, 2016
    22
    I am raising this as a new topic as it may get lost where it currently sits under the topic Yealink T23G provisioning.
    I have just re-installed the software (as I now have a purchased copy) and there appears to be a problem setting the TIMEZONE information on setup - although I can choose the country it doesn't register - see the screenshots I took of both sections where I am supposed to choose the country/timezone from a drop-down list.
    No matter what I do (press enter, double click etc) the fields refuse to populate.
    Terence
  2. seebacher
    May 6, 2008
    20
    yes same here.... + how can i change this setting after the installation?
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Unnecessary tab on single instance?
    maybe 3CX should use regional settings of OS :?:
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,444
    463
    Open a cmd and perform an nslookup command for downloads.3cx.com and erp.3cx.com and see if you can resolve to our servers.
    Also try replacing your DNS server settings on the PBX machine and use 8.8.8.8 for your primary DNS
    After changing the DNS perform a ipconfig /flushdns.
    Also perform all windows updates, restart the machine and perform the setup again.
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    444
    73
    Also make sure you use a 3CX v15 supported browser. Internet Explorer will not work properly.
  6. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Re: Unnecessary tab on single instance?
    This is the most logical and simplest solution but 3CX seemingly refuses to do it.
  7. sunkiddance
    Jul 12, 2016
    22
    Hi YiannisH
    I am not sure how your suggestion is going to help.
    I get a drop-down list of countries but the install will not let me select one - all I end up with is the solid bar of colour without selecting any country (as per the screen shots).
    Both addresses resolve correctly with nslookup
    Terence
  8. YiannisH_3CX
    May 10, 2016
    6,444
    463
    What browser are you using to complete the wizard?
  9. sunkiddance
    Jul 12, 2016
    22
    Thanks to lifeline for pointing this out to me - I was using IE - now changed to Chrome
    So - I backed up my V15, un-installed it and then re-ran the install (with Chrome now set as my default browser)
    But because I restored from my backup, it never asked me what timezone I was in.
    So we are back to the issue, that one should be able to change the timezone in the management console without having to un-install and re-install the software especially as if you restore from a backup the prompt never comes up.
    Terence
  10. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Or 3CX could just use the server time and skip all this hullabaloo.
  11. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    Although a good idea, not possible. There are many cases where the actual server is in one Timezone but the PBX is 'servicing' users in a different timezone.
    Also, seeing that the Multi-Instance is (well ,will be when it comes) based in the Single Instance, what happens when you have a different Timezone per instance?
  12. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    What about an option in settings with options to sync with server or manually set timezone. It also needs some way to easily and reliably set DST, without having to dig around in advanced parameters.
  13. gd1
    gd1
    Feb 17, 2015
    6
    Have you guys tried to edit the Parameters under "Settings"?
    I was able to modify the time zone manually for my Yealink phones.
    You will need to scroll all the way down near the bottom.
    Once I made the changes I rebooted the server and the time zone was applied.
    Hope this helps someone out.
  14. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Should that match country/state in registration tab?
    In any case, the point is to avoid unnecessary scrolling. Config tool should detect local time zone and country which later can be preselected in wizard. There is also no need for time zone menu in many countries(map it internally).
    Code:
    // FindSystemTimeZoneById
    // The example displays output like the following when run on a system in the
    // U.S. Pacific Standard Time zone:
    //       Time in Pacific Standard Time zone: 12/6/2013 10:57:51 AM
    //          UTC Time: 12/6/2013 6:57:51 PM
    //       Time in Tokyo Standard Time zone: 12/7/2013 3:57:51 AM
