Can not specify static IP
Discussion in '3CX Phone System - General' started by blabla, Apr 11, 2008.
  1. blabla
    Jan 20, 2008
    32
    If I try to add and VoIP Provider Line and specify the outbound IP (Which IP to use in 'Contact' field for registration: Specified IP) I invariably get: "A prvider Specifies IP is invalid", while the IP is valid.
  2. paragondie
    Jun 25, 2007
    52
    We have been having the same problem. What we do is change the ip of the server, setup the voip provider with the ip we want to use and then set the box back to the address. It won't let you set up the provider with the same ip as the box.
  3. mickp
    Jun 9, 2008
    72
    Thanks for the tip. I can confirm that this is still a problem in 6.1.0. I don't mind there being a warning but it's _very_silly_ that such a disruptive workaround has to be used to set a perfectly valid setting.
    Can someone with access to the VP forum raise this as a bug (or is there another place to log defects that I'm missing)? It doesn't seem like a "feature request" to me.
    Mick.
