Can Only Hear Sound Both Ways During Transferred/Forwarded Calls
Discussion in '3CX Phone System - General' started by olivermsubadra, May 5, 2016.
  1. olivermsubadra
    Feb 18, 2016
    33
    Audio for all calls that are forwarded/transferred works fine. However, any immediately received/made calls only have one-way audio: a caller/callee to one of our softphones cannot hear any sound from the softphone making/receiving the call (but the softphone user can hear the voice of the other party).
    As far as I can see the log doesn't point out any difference between the call being made to the original extension and the 'forwarded version' of the call:
    Code:
    05-May-2016 14:34:55.155   Leg L:4.1[Line:10000<<[NUMBER]] is terminated: Cause: BYE from PBX
    05-May-2016 14:34:55.155   [CM503008]: Call(C:4): Call is terminated
    05-May-2016 14:34:55.155   Leg L:4.3[Extn] is terminated: Cause: BYE from 10.195.194.40:57081
    05-May-2016 14:34:45.865   Leg L:4.2[Extn] is terminated: Cause: BYE from 10.195.194.3:5401
    05-May-2016 14:34:45.759   [CM503007]: Call(C:4): Extn:431 has joined, contact <sip:431@10.195.194.40:57081>
    05-May-2016 14:34:45.758   L:4.3[Extn] has joined to L:4.1[Line:10000<<[NUMBER]]
    05-May-2016 14:34:45.758   NAT/ALG check:L:4.3[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    05-May-2016 14:34:43.090   [CM503025]: Call(C:4): Calling T:Extn:431@[Dev:sip:431@10.195.194.40:57081;rinstance=728f464cb708760f;transport=UDP] for L:4.1[Line:10000<<[NUMBER]]
    05-May-2016 14:34:43.038   [CM503027]: Call(C:4): From: Line:10000<<[NUMBER] ("[NUMBER]:401" <sip:[NUMBER]@[DOMAIN]:5060>)  to  T:Extn:431@[Dev:sip:431@10.195.194.40:57081;rinstance=728f464cb708760f;transport=UDP]
    05-May-2016 14:34:43.038   [CM503004]: Call(C:4): Route 1: from L:4.1[Line:10000<<[NUMBER]] to T:Extn:431@[Dev:sip:431@10.195.194.40:57081;rinstance=728f464cb708760f;transport=UDP]
    05-May-2016 14:33:47.664   [CM503007]: Call(C:4): Extn:401 has joined, contact <sip:401@10.195.194.3:5401>
    05-May-2016 14:33:47.663   [CM503007]: Call(C:4): Line:10000<<[NUMBER] has joined, contact <sip:01296531460@tartarus.tipicall.net:5060>
    05-May-2016 14:33:47.663   L:4.2[Extn] has joined to L:4.1[Line:10000<<[NUMBER]]
    05-May-2016 14:33:47.663   NAT/ALG check:L:4.2[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    05-May-2016 14:33:42.681   [CM503025]: Call(C:4): Calling T:Extn:401@[Dev:sip:401@10.195.194.3:5401;rinstance=da050df101fb7142] for L:4.1[Line:10000<<[NUMBER]]
    05-May-2016 14:33:42.634   [CM503027]: Call(C:4): From: Line:10000<<[NUMBER] ("[NUMBER]:401" <sip:[NUMBER]@[DOMAIN]:5060>)  to  T:Extn:401@[Dev:sip:401@10.195.194.3:5401;rinstance=da050df101fb7142]
    05-May-2016 14:33:42.634   [CM503004]: Call(C:4): Route 1: from L:4.1[Line:10000<<[NUMBER]] to T:Extn:401@[Dev:sip:401@10.195.194.3:5401;rinstance=da050df101fb7142]
    05-May-2016 14:33:42.633   [CM503001]: Call(C:4): Incoming call from Line:10000<<[NUMBER] to <sip:401@10.195.194.10:5060>
    05-May-2016 14:33:42.633   NAT/ALG check:L:4.1[Line:10000<<[NUMBER]] REQUEST 'INVITE' - basic check passed. No information for extended checks
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    Are the "Supports Replace" and Supports Re-Invite" option in the Provider Settings -> "Advanced" unchecked? Also PBX Delivers Audio there should be checked.
    If that is OK, then this will probably be easier to troubleshoot using Wireshark to see exactly what is happening...
