can PATTON sn4170 gateway configure?
Discussion in '3CX Phone System - General' started by oosaki, Jun 30, 2017.
Tags:
  1. oosaki
    Jun 30, 2017
    We are building 3CX PBX with PRI.
    For enabling outbound i/f,we borrowed PATTON sn4170 gateway from 3cx seller.
    At configureing SIP Trunks,
    1,Add gateway
    After filling information ,
    2, Generate device config OK .
    ->appeared a row (RED indicate)
    ->no gateway web(for import config)
    (~imp-cfg.html not found)
    can use PATTON sn4170?
    pls help me!
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yes 4170 works but youll most likely need to manually configure it. Ive setup a few recently.
  3. oosaki
    Jun 30, 2017
    Thank you for your information.
    Very helpful!
    I've decided to continue using sn4170.
