Can the voicemail e-mail be edited?
Discussion in '3CX Phone System - General' started by joepmaas, Feb 2, 2009.
  1. joepmaas
    Feb 2, 2009
    17
    Is there a possibility to edit the email that is being sent to notify a voicemail-message? :idea:
    Any help to locate the text and preferably indicate variables used would be much appreciated! :lol:
    Many thanks in advance...
    Joep
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    At this point in time this is not possible. Kindly post as a Feature request.
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    It could be just me, but the layout in version 6 was much better. I now get some, not so clear email.
    Can we change it back to the Version 6 template ?
    H.
