Can we get status of all extensions via a web call?
Discussion in '3CX Phone System - General' started by millsey, Dec 22, 2011.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    We want to get all current extension statuses to use in a php application we have built, we can be very flexible ourselves. Is ther a URL we can call (we cannot use the API as that would require c# programming) to get the data which is displayed in the Extension Status wscreen of the Manager? Or is there any other way to do a live query of all extension statuses?
    Millsey
  2. simonatkins
    Nov 2, 2011
    9
    The only way to get into 3CX is via the api, so you're going to have to learn c# or... you could pay for a software house to write a c# service that uses the api and has a listening socket on it. Then you could send requests to it in php, get responses, format and show in a web page.
    rgds
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Try to search in google for
    "How to use .NET assemblies in PHP?"...
