can we record ALL calls by default on 3cx Professional
Discussion in '3CX Phone System - General' started by seanc, Jul 14, 2015.
  1. seanc
    May 25, 2015
    25
    i know you can set 'record calls' in each extn.
    is there a tickbox to record ALL calls / every extn, in and out by default?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,048
    156
    Did not think there is,
    But you can select multiply extensions then click on edit extension, will allow you do change the setting
  3. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Call recording is set per extension and there no way to set it globally. You can certainly choose multiple extensions and tick to record calls once for all of them.
