Can we use Port 80 for registration and conversation?
Discussion in '3CX Phone System - General' started by jeromenew, Jul 25, 2009.
  1. jeromenew
    Jul 25, 2009
    I am Jerome new to this forum,
    I would like to know is it possible to use Port 80 instead of 5060.
    Because some times the ISPs are blocking the use of SIP or VoIP stuffs to be used in their network.
    If we use port 80 it always works.
    in SIP port number we should use port 80
    As well as we should use the register proxy name followed by :80 (proxy name:80)
    Just let me know the possibility of this.
    Thanks and Regards
    G. Jerome
  2. ole
    ole
    Feb 5, 2009
    10
    You can change the port under Settings|Network (Sorry, I have the German version, thus I do not know if this is exactly what it looks like).
    But normally, this should not have any effect on blocking VoIP traffic. It is the same as stating 'We will talk in English over this line'. If you talk in Russian and somebody listens, he will at least know that this is definitely not English. So, if you use port 80, your provider will know that you definitely do not talk http over that port...
    Don't know how long this will work.
    Ole
  3. thenua
    Jun 5, 2009
    38
    Hi jeromenew,
    I believe its a question chiefely for your SIP provider.
    I think most do not allow for registration on Port 80. But I also know of a SIP provider near me that does allow it.
    Perhaps try it first with your SIP provider and see how you go.
    Regards
    thenua
  4. abouelric
    Jan 17, 2009
    32
    You can use the "3cx sip tunnel proxy manager" and register the tunnel through port 80 and it works fine. for more information check this url http://wiki.3cx.com/documentation/networking/sip-proxy-manager
    hope this help
    good luck
