Can you edit message options menu? IP Phone only.
Discussion in '3CX Phone System - General' started by PaulGarcia, Dec 15, 2014.
  1. PaulGarcia
    Aug 6, 2014
    8
    3cx v12.0.37098.738 SP.6.1
    With a supported Cisco SPA504G, press message, enter PIN, then.... (press 9) you can then change your Profile in the prompted (heard) menu. i.e. from "Available" to "out of office" by using the key pad only. (No MyPhone). This is a good feature.
    Is it possible to change other parts of this menu? i.e. the forward to number, etc? Or is this programable somewhere else? Any information of manual information pleae?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi Paul,
    Unfortunately this menu cannot be altered, please post this as a feature request on 3CX Ideas : http://www.3cx.com/ideas
