Can you forward a call directly to someones VM
Discussion in 'Windows' started by north3, Jul 24, 2012.
  1. north3
    Jul 3, 2009
    9
    Can you forward a call directly to someones VM?
    10,362
    227
    When doing a transfer, precede the extension number with *4
  3. Rami.Hachem
    Jul 25, 2012
    9
    is there a way while doing the transfer to add a button to transfer directly to a voicemail instead of adding 4 manually?
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    It doesn't seem to work on the Softphone. I tried Speed Dial and BLF.
    BLF doesn't seem to do anything.
    SpeedDial dials *4 and it rings and then goes silent.
    On a deskphone, I use a button type called "PREFIX" and add *4
    So we label the button DVM.
    So transfer, DVM ####, transfer,
  5. leejor
    10,362
    227
    I seem to recall that one user made use of dummy extension and call forwarding. Extension 202 had a dummy set up (Ext 102) that was forwarded to *4202, so if you wanted to go directly to the mailbox, you sent the call to the dummy extension associated with the real number.
    I hope I'm remembering that correctly, and that it worked. Wouldn't be a lot of effort to try it out
  6. Rami.Hachem
    Jul 25, 2012
    9
    Are there any plans to include transferring to user's voice mail via the client?
    Thank you,
    Rami
  7. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You can setup a dummy extension and set the forwarding options to forward to another extensions voice mail immediately, or in this case as there will be no handset/phone involved you'd set to forward to vm if extension isnt registered.
  8. jpillow
    Jun 20, 2011
    1,342
    When you say Client I'm assuming you are referring to myphone if that is the case you have two options you can either dial *4 and extension ie *4102. When forwarding to VM for extension 102
  9. craigreilly
    Feb 1, 2012
    2,962
    180
    You say two options - what is the second option?
