Can you have multiple phones registered to one extension?
Discussion in '3CX Phone System - General' started by Ralph, Feb 17, 2008.
  1. Ralph
    Ralph Member
    Jun 28, 2007
    417
    I seem to recall reading that the new version of 3cx can have multiple phones registered to the same extension.
    Is this possible in V5.1? If so how does it work? Do both phones ring when the extension is called? Are there some special steps or setup that needs to be done to implement this?
    Thanks again
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,258
    97
    There is no way to register 2 devices using the same account. That is not a 3CX limitation, that's how SIP works.
    To get that behavior, what you can do is to create a ring group, and add all the extensions you want to that ring group.
  3. edossantos
    Jun 27, 2007
    1,258
    97
    Sorry, I didn't saw that new functionality. That's true, I tested it here.
    Just register two devices using the same credentials, and that's it.
    Sorry again, I'll try to read a little bit more next time :)
  4. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good morning,
    That is great news :)
    I had been doing it with multiple extensions and ring groups for clients that wanted a phone to ring at the office and at home.
    Thanks again
  5. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Yes I have also had this working
    Stephen
  6. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    So, does both ring at the same time if you call the extension?
  7. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Yes did for me
    Stephen
  8. respecte
    Feb 20, 2008
    10
    That is the beauty of sip, not a special config of 3cx, but generally available in all voip implementations i have used.
  9. garrycarpenter
    Nov 28, 2007
    20
    I now have three phones registered to one extension!
    One Wifi WIP330
    One Desk Phone SPA941
    One External Phone SPA941 (at home)
    When my extension rings, all three phones respond....
    No need to divert phones to external numbers now :D
  10. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    yes, work pretty well and its a usefull option
    regards
