Can you reset a extension from the console?
Discussion in '3CX Phone System - General' started by cjammer, Feb 18, 2008.
  1. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    I have done something odd and with one phone call managed to get three extensions tied up. Once I hung up, they never reset. a quick check on the ole copper line verified that it truly had the lines tied up.
    So My question to all is from the console can I reset a phone? aside from unplugging everything and let it reset, what else can I do?
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    This feature is not available but it would be a nice one to have. Perhaps you should post in in the feature request forum.
  3. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    I have often wished for the ability to go to the Line status screen and be able to see what each line or extension is doing, then click on the extension and get management features of the particular device. At that point you can delete it or edit it or reset it.
    Maybe in a future version.
