Can you send Text Messages?
Discussion in '3CX Phone System - General' started by Aussie, Jan 28, 2013.
  1. Aussie
    Jan 28, 2013
    As the topic says, can you send messages / text with the 3CX phone system?
    I tried the Windows application but saw no feature which supported this.
    I looked into the .NET API and also saw no method which supported this.
    I'd say it's not possible but i'd like to get some confirmation first.
    Can you?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    I am sending text messages with Yealink phone :D (locally between extensions)
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You can use MyPhone for IM with any phone, but I think the question is about GSM SMS.
    Probably some GSM gateways with web interface or some providers (also web interface) will do the job.
    Regards
  4. Cynthia Slade
    Mar 22, 2012
    45
    Are you asking if you can send text messages internally or externally?
