Cannot Access Passive Server On New Lightsail Instance
Discussion in '3CX Phone System - General' started by Wendelspanswick, Dec 6, 2018 at 6:37 PM.
  1. Wendelspanswick
    Wendelspanswick New Member
    Jan 11, 2016
    143
    We have an Enterprise Licence on our active server which is hosted on UKFast and we have set up a passive server on Amazon Lightsail using PBXExpress and the same licence details.
    Everything seemed to go perfectly, the management console opened up, the FQDN switched to the passive server so I opened the licence on the active server and restarted the services so the FQDN reverted back to the active server.
    But I can no longer web browse to the IP of the passive server, it just says `Refuses to connect`, I tried from a different network in case I'd been blacklisted but still nothing.
    The instance shows the VM up and running, Terminal Window shows the services as running, I've rebooted the instance but nothing.
  2. Wendelspanswick
    Jan 11, 2016
    143
    Solved it, had to go in via port 443 even though the instance has a custom access of 5001?
    #2 Wendelspanswick, Dec 6, 2018 at 6:45 PM
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,557
    234
    Aren't the services supposed to be stopped on the passive server? Honestly it took so long for the fail-over component to come out we don't use it so I've never tested it. Just failing over the VM is much easier and more robust in most cases. Were it active-active that would be another story.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Hello @Wendelspanswick
    You mentioned the passive instance was installed through PBX express. In that case post 443 is always used. I see some issues with failover if you are using different ports on the 2 servers so i would recommend re-installing one of the two instances so they are identical.
