cannot add sound file to prompt of digital receptionist
Discussion in '3CX Phone System - General' started by lennyli, May 10, 2009.
  1. lennyli
    May 2, 2009
    10
    hi
    i have installed 3cx on a windows 2008 system with internet explorer 8 installed.
    in the edit digital receptionist screen, i click the browse button to try to input a sound file for the prompt. however, the browse button only brings up a 'choose a file' dialog with add and remove buttons. when i click the add button, nothing happens, so i cannot specify a file to use.
    can someone please help me overcome this bug/problem?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hi,
    there is some bug with IE8 interface on 3cx administration. if you try with firefox there is no bug like this.
    IE8 is more recent and we can suppose some bug will resolve in next version of 3cx.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    At the moment it would be best to use IE 7 or Firefox.
    Those Browsers dont have such problems afaik.
