Cannot add voip provider: An exception occurred AccountDetai
Discussion in '3CX Phone System - General' started by meshuga, Apr 29, 2009.
  1. meshuga
    Feb 24, 2009
    16
    I did not do any sort of upgrade and when I goto Add Voip Provider I get:
    An exception occurred AccountDetails Error: Object reference not set to an instance of an object.
    I am using 4 digit extensions so the patch at:
    http://www.3cx.com/forums/can-not-add-voip-provider-after-upgrade-8638-15.html
    does me no good. Any other ideas?
    I have tried:
    Generic SIP Trunk
    Generic VOIP Provider
    Generic VOIP Provider (compatibility)
    I have setup half a dozen other setups fine without this error.
  2. meshuga
    Feb 24, 2009
    16
    I really don't want to have to reconfigure everything I just got done setting up all the extensions.
    Any ideas guys? This is a fresh install with 2 dozen extensions, but without being able to add providers I lose alot of functionality..
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    What is your configuration - OS and Version?
  4. meshuga
    Feb 24, 2009
    16
    OS is Windows 2003, version is latest from the website. I don't have that system handy but I could plug it in if anyone has any suggestions. I have got this before at the beginning and did a full uninstall and reinstall and it fixed it, but I don't want to do that in case I hose the data.
    Sorry in the delay, it never emailed me when a reply was posted.
    Thanks!
  5. leejor
    11,127
    330
    I would hope that you've done a back-up. If it comes down to having to do a reinstall then you haven't lost all your work. If you've installed 3CX successfully in the past then I would suspect the problem is with the computer you are installing it on this time, and unfortunately, that leaves a lot of variables. Have you only tried one install on this particular machine? If a re-install in the past fixed this sort of thing then I would suspect some corruption during the first install.
  6. telica
    Nov 26, 2008
    9
    I had a very similar problem to this and it was because my licence number had not been registered on the 3CX properly.
    The Best way to check is to open the "3CX Assistant" log it on to an extension and see if it shows "Free Version".
    If it does then simply re-enter your licence information and restart the services.
    Many Thanks
    Steve
  7. ciscotech2007
    Jan 27, 2009
    94
    sounds like a DB error and/or web server error, probably web server or web data issue. Besides rebuilding or restarting either from 3CX development... only way I got around this was a full backup and reinstall (using install checker to remove all old versions).
