Cannot answer call
Discussion in 'Windows' started by quickvet, Jan 20, 2011.
  1. quickvet
    Jan 20, 2011
    Hi, I wonder if anyone can shed any light on my problem. Recently my 3CX Softphone has stopped allowing me to answer calls. When I click on the Green connect button it switches to the main screen and the Line1 flashes but nothing will convince it to actually answer the call. I am not aware of doing or changing anything so it is a bit of a mystery.
    TIA
    10,368
    228
    No other problems placing calls or other issues? You could always delete and re-install, I've found that on occasion (usually very rare) corruption occurs in a PC programme and for no reason it miss-behaves until re-installed. No logical explanation as to why it would act up in the first place.
  3. quickvet
    Jan 20, 2011
    Ok, I re-installed and still have the same problem. It is very odd as it worked fine for some time. Any more ideas out there?
  4. zinzaba
    Aug 12, 2009
    6
    I have the same problem.
    Anyone have any ideas? The phone registers fine.
  5. tumler100
    Mar 29, 2012
    I usa a the softPhone with a VOIP-provider on a windows 7 platform.
    The first time after restart or forced relogon (i'd like a button for this) calls get through.
    Seems 3cx does'nt handle the end of calls correctly. It won't log the calls. Incoming calls get through but I get the same problem as quickvet. Neither can i make Outgoing calls after first call.
