Solved Cannot call outside with OVH trunk and last free 3CX on VPS
Discussion in '3CX Phone System - General' started by cyclone76, Mar 3, 2017.
  1. cyclone76
    Mar 3, 2017
    44
    I am a new user and perhaps a futur custumer.
    I use last free 3CX version on OVH Debian 8 VPS (without firewall). Firewall check is ok.
    I have rent a trunk on OVH ans it is a on line (green) an appears as connected on OVH dashboard.
    I programmed inside and outside rules (one each).
    So i can receive calls on extensions but i cannot make outside calls with any extension.
    Each time i try to call outside, (with Windows or Android phones), i shortly see the word "connected" and i ear message "Call forbidden by admin". Then on 3CX dashboard's log i read : "Call or Registration to 0xxxx53@(Ln.10000@Trunk OVH-1) has failed. xx.121.xx.xx replied: 403 Wrong login or password; from IP:xx.121.xx.xx:5080" and "Extension 002 is unregistered, removed contact: sip:002@xx.103.xxx.xxx:50195;transport=TCP;rinstance=1-lrbuixgdo4tv0jax5lyloch.lgqexcyu;ob;inst="8c470180".
    Trunk account is ok because i tried outside calls directly on a sip phone.
    Thnaks for help.
    Regards ;
    Fredo
  2. cyclone76
    Mar 3, 2017
    44
    I resolved my problem using Generic trunk modele instead OVH trunk model.
    All is ok now.
    Regards
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Glad to know the issue is resolved and thank you for sharing your solution
    cyclone76 likes this.
  4. cyclone76
    Mar 3, 2017
    44
    Hi sir,
    I think that it did not work because i have not presented the outside ID caller in the trunk field.
    I retried with Ovh trunk model and the both are ok.
    Regards
