Cannot call specific number
Discussion in '3CX Phone System - General' started by livn46, Mar 18, 2016.
  1. livn46
    Oct 24, 2014
    78
    I have a user who is attempting to call a specific number in Nigeria (we are located in the United States). He has tried 4 calls, and I have now tried 3 calls. Every attempt fails: about half of the time the logs have SIP response code "606 Not Acceptable", and half of the time the logs have SIP response code "403 Forbidden". What could be going on here? We have made other calls to Nigeria successfully, but it's something about this particular number? Is it a codec issue? I tried with only GSM and G.722 enabled, and then again with all codecs enabled, and both failed. I'm not sure what else to try.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,325
    253
    Best bet is to call your provider and see what the reason for the error is.
  3. leejor
    10,767
    286
    In some cases, calls will fail (be blocked) if the number being called incurs a "larger than usual" connection charge, especially if the provider has has past experiences with the number, or number range. As suggested, your provider can confirm.
  4. daktur
    daktur New Member
    Oct 15, 2015
    226
    7
    I Think this is a provider problem not a pbx issue. I had the same problem with Broadvoice and they figured out since i was calling *rare* number or unknown provider numbers the system does not know how to route the call properly and it simply timeouts the try.
    One of the number I was try is something like *31110000 for example...
