Cannot change Mail Server Configuration (greyed out) - Standard lic.
Discussion in '3CX Phone System - General' started by Jeremy Bero, Mar 6, 2018.
  1. Jeremy Bero
    Dec 29, 2017
    13
    Product: Standard Annual
    Version Number: 15.5.0
    I chose 3CX SMTP server during initial setup and it does work but we want to change this now and cannot.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
  3. Jeremy Bero
    Dec 29, 2017
    13
    Thanks.
    That must have changed recently. It also now states "Custom FQDN" is not supported in Standard yet it let us use a custom FQDN (shhhh, don't tell).
  4. Saqqara
    Mar 12, 2014
    1,252
    203
    Changed in 15.5 SP3, if you were using a custom FQDN before the upgrade you are allowed to use it
    #4 Saqqara, Mar 6, 2018
  5. StefanW
    Jun 2, 2009
    1,222
    93
    and if you where using custom SMTP before too....
