Cannot change personal greeting
Discussion in '3CX Phone System - General' started by rhnkllmn, Apr 10, 2013.
  1. rhnkllmn
    Apr 10, 2013
    Hi Guys
    I am having a problem with changing the personal greeting on my phone . I have tried restarting the voicemail service and that makes no difference .... what do i do next
  2. jasit
    jasit New Member
    Feb 12, 2013
    171
    Here is what I added to the welcome message, see if it works for you.
    Change Voicemail Pin number
    Press 7
    Enter new pin code
    Press #
    Verify message
    Press *
    **** Once you change your pin number you will also need to
    change it for the 3cx Myphone app so that it doesn't lock you out.
    Greeting Name
    Press "5" to change your greeting name (not your message, just your name) Press "0" when ready to say your greeting name"
    Press "#" when completed
    Press "0" to save the new greeting name
    Voicemail Message
    Press "8" to change your greeting name (not your message, just your name) Press "0" when ready to say your greeting name"
  3. 3397premier
    Apr 2, 2012
    43
    I have had this problem before. For whatever reason I have had to delete the greeting manually on the 3CX server for that extension and then have them go back in their voicemail and re-create it.
    Go here: C:\ProgramData\3CX\Data\Ivr\Voicemail\Data
    Select extension that has issue and delete the savevmgreeting.wav file
    It will be recreated when they go back in. Cheers!
