Solved Cannot change SMTP settings
Discussion in '3CX Phone System - General' started by Phillip Heuchert, Nov 14, 2017.
  1. Phillip Heuchert
    Nov 13, 2017
    I can't send welcome emails-- I went to check on the SMTP configuration (which I have never touched), the server drop-down menu is grayed out and I can't change any settings. When I click the TEST button, I get the authentication error you see below..
    Any ideas??
    [​IMG]
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,109
    166
  3. Phillip Heuchert
    Nov 13, 2017
    Thanks-- I just figured it out. I found out my Public IP settings were incorrect. Fixed it, and now I can send/receive emails.
  4. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Glda to see the issue was resolved.
