Cannot consistently receive inbound calls
Discussion in '3CX Phone System - General' started by wynd, Jul 20, 2007.
  1. wynd
    Jul 20, 2007
    I need to constatntly re-register my line and I can't figure out why. I can get 2,3 or 4 inbound calls, then the system won't answer any calls. I see the inbound call, but it doesn't seem to answer it. Any ideas on what i can do to see what should be happening in more detail - i have a generic configuration. My vendor is Broadvoice.
    Time Function Message
    13:32:02.015 CallLegImpl::eek:nConnected Call(C:18): Created audio channel for Ln:5000@broadvoice (147.135.12.250:25246) with Media Server (69.95.84.72:9002)
    13:32:01.953 CallConf::eek:nIncoming Call(C:18): Incoming call from Ln:5000@broadvoice to sip:2013010288@192.168.1.201
  2. Anonymous
    Anonymous Guest
    How do you have this configured?
    I assume you only have this login on 3cx and not on an ATA?
  3. wynd
    Jul 20, 2007
    I have an XP machine, with ethe 3cx server and took the defaults. There's several extensions and only 1 line.
    Is there more debug information that I can turn on?
