Cannot create profile on HTC Tattoo
Discussion in 'Android' started by MikeAlpha, Jul 13, 2010.
  1. MikeAlpha
    Jul 13, 2010
    I'm trying to install the 3CXPhone on an HTC Tattoo. It installs fine but never asks to create a profile. When you access the profiles on the phone it says "Profiles are unavailable" so I cannot set it up to register with our SIP provider. It looks like a bug in the 3CXPhone software - has anyone else seen this type of behavior?
    Thanks.
  2. jwnesbitt
    Sep 19, 2009
    48
    I have the exact same issue on my HTC Desire
  3. jwnesbitt
    Sep 19, 2009
    48
    any ideas on why or if there is a fix,
    reading the reviews on the android store, its quite a common issue
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    This is usually an issue when a storage device / memory card is not available to write the profile to.
  5. jwnesbitt
    Sep 19, 2009
    48
    brilliant, thanks
    thats fixed it for me
  6. baran
    Sep 29, 2011
    I have this problemon motorola milestone android 2.2.1 and the sd card is there !
