Cannot dial out from PAP2T
Discussion in '3CX Phone System - General' started by muaddib32, Feb 10, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    Trying to set connect a fax machine to a Linksys PAP2T ATA and then to the 3CX.
    The PAP2T is registering and if I connect a analog handset I can make internal phonecalls. The fax machine can receive faxes. However, either using the fax machine or analog handset I cannot make outbound calls. I just get a busy/engaged tone.
    I imagine it is something simple but is someone able to point me in the right direction?
    Regards
    Ben
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    PAP2T is not supported, especially for fax and I have had minimal luck with it.
    If you need the 2 lines then replace it with the linksys SPA2102 and set one of the extensions as a fax extension in 3cx.
  3. leejor
    11,105
    329
    There is a very recent firmware update for the 2102 that adds a few "fax friendly" options.
